7921/7925 problem with french locale
With a 7925 using 1.4.1 version (and CUCM 8.6), the entreprise directory menu is in English language instead of french one like the others.
The locale version is CCM-locale-fr_FR-8.6.1.100-1
I did no find any bug or any compatibility matrix between  locales vesrions and Phone software version.
Could you help me to find some elements ?
Thanks in advance
Blue
Have you installed Phone Locale.
We have to install both CUCM locale for French language + Phone specific locale.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Yes. I forgot tell you we have no problem whe use 1.3.4 SR1 version for the 7921/7925 (directory is in french). that's the reason I would like to find document to check compatibility.
Blue
It should be supported
See read me of the pack , it state 7921/7925 are supportd for french locale.
http://www.cisco.com/web/software/282074333/51763/cm-locale-8.6.1.1000-2-ReadMe.txt
Ronak patel
393
