7921 firmware upgrade
I am in the process of trying to upgrade a Cisco 7921 handset from firmware version 1.0.5. Does anyone know if i can go directly to 1.4.4 or do i have to go to an interim version like other 7900 handsets before going to 1.4.4. I am struggling to find documentation for this
Derek
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Derek,
I had a look at these Firmware release notes for the 7921;
And the only install note that I can see is this one;
Upgrade from Releases Prior to 1.4(3)
If your Cisco Unified Wireless IP Phones are currently running a  release prior to 1.4(3), then you must use the Trivial File Transport  Protocol (TFTP) method to upgrade to release 1.4(3) or later.  Once  upgraded to release 1.4(3) or later, you can then upgrade to later  versions using the phone's webpage either via USB or WLAN.
From;
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g_7925gEX_7926/firmware/1_4_4/english/release_notes/P256_BK_WDE25DD7_00_wireless-phone-release-notes-1_4_4_chapter_00.html#P256_TP_UDC0BE34_00
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Hi Derek,
From;
Cheers!
Rob
- The Band
thanks Rob. That worked a treat.. Strange phones
230
