Community Member
7921 problem after upgrade to 1-3-3
Hello forum!
I am running CM 4.2(3) and after the firmware upgrade of the 7921 to 1-3-3 I have problems.
It registers normally but after some hour the message "NOT IN SERVICE" appears. Then it resets and the initial steps happen again:
1. Opening 172.16.x.x (cm ip)
2. Configuring IP
3. Confiruring CM List (somethimes it freezes)
4. Opening 172.16.x.x (again... and it freezes)
Any suggestions?
Firmware problem? Wireless problem?
Thanks in advance
1 REPLY
Community Member
Re: 7921 problem after upgrade to 1-3-3
We run 4.13SR8a and have hundreds of 7921s and a handful of 7925s with no problems that you are describing.
296
