Community Member
7921-Reg Rejected.
First attempt at getting a 7921 up and running.
7921 is connected to WLAN and pingable, and browseable to http.
7921 connects to CM and recieves firmware upgrade w/ no problem. Running 1.1.1
CM is running 4.1(3)sr2
Phone is added to the CM however only recieves a "Registration Rejected"
1 REPLY
Community Member
Re: 7921-Reg Rejected.
hi
do check whether auto-registration is enabled and also check the DNs,as the range which u would have specified be used already
regards
kumar
127
