7925 Support
refram
Level 3
Level 3
I'm having a heck of a time trying to get my CUCM 6.1 server to allow me to add a 7925 phone.  I have upgraded the O/S to 6.1.1.3104-1.  I have installed the latest 7925 firmware, but when I go to add the phone, there's only a 7921.  I've tried installing the device pack "cmterm-devicepack6.1.1.3117-3.cop.sgn", but it doesn't seem to help (by the way, I've never installed a device pack before...if it is supposed to change the O/S version, this one hasn't).
Suggestions?
David Hailey
You are the Refram.
See https://supportforums.cisco.com/message/1158368
See https://supportforums.cisco.com/message/1145571
Rob Huffman has a good note in there on the topic and I believe that in cursory review of it, you need to get to 6.1(2) and then install your device pack.
http://www.cisco.com/web/software/282074289/23369/cmterm-7925-sccp.1-3-1-Readme.html
Hailey
Please rate helpful posts!
David Hailey
You are the Refram.
Hailey
Thanks Hailey (+5, monsier).  Just so you know, I spend a fair amount of time searching the general Cisco site, NetPro and Google before asking things.  One day I'll send you my laptop and see if you can figure out why my browsers tend to filter out all useful posts.  Sometimes I have to wonder.
I'm working on the 7925 issue now.  I'll let you know how it comes out.
Rob Huffman
Hey Refram,
A couple of notes here
The install of a Device pack does not change the base O/S version so this is an expected result.
The 7925 was never added to CUCM 6.1(1) versions as Hailey nicely noted, so an upgrade to 6.1(2)
as a minimum is required.
For NetPro searches you will find that "keywords" are a must!
For this question try;
7925 supported
7925 Device Pack
7925 model available
and you will find your search will yeild a number of valid threads.
Cheers!
Rob
Just to add something.
You mentioned you installed the DevPack, have you rebooted the cluster after that????
The README explains that if you install the DevPack for new model support, a cluster reboot is MANDATORY.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
