Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
7925 Wireless Phone and CCM 6.0
Looking at the datasheet for the 7925 it seems that the phone is widely supported across many CCM versions.
Does anyone know what version of 6.0 needs to be installed to add a phone in CCMAdmin?
The menu goes from 7921 --> 7931.
Aaron
Hall of Fame Super Silver
Re: 7925 Wireless Phone and CCM 6.0
You should be able to get it to work with the latest device pack.
HTH,
Chris
Hall of Fame Super Red
Hi Aaron,
Here is a little additional info to the good tips from Chris (+5 points Chris - Happy Holidays)
Before installing the firmware, use Table 1 below to verify that your Cisco Unified Communications Manager supports the Cisco Unified Wireless IP Phone 7925G. If your Cisco Unified Communications Manager does not support the Cisco Unified Wireless IP Phone 7925G, you will need to upgrade to a Cisco Unified Communications Manager release that supports the phone and/or install a device pack that will add the support for the phone.
Table 1: Cisco Unified Communications Manager Release Requirements for Cisco Unified Wireless IP Phone 7925G Support
CUCM Release
Minimum Service Release (SR) Required
DevicePack Required?
DevicePack Minimum Release
Notes
4.1(1) - 4.1(3)
Yes
4.1(82)
Install device pack
4.2(1) - 4.2(3)
Yes
4.2(3.55)
Install device pack
4.3(2)
Yes
4.3(2.08)
Install device pack
5.1(1) - 5.1(2)
5.1(3)
Yes
5.1.3.4114-2
Upgrade to 5.1(3) and install device pack
5.1(3)
Yes
5.1.3.4114-2
Install device pack
6.0(1)
Yes
***DevicePack Minimum Release 6.0.1.3112-1
Install device pack
6.1(1)
6.1(2)
Yes
6.1.2.1120-1
Upgrade to 6.1(2) and install device pack
6.1(2)
Yes
6.1.2.1120-1
Install device pack
7.0(1)
Yes
7.0.1.12004-1
Install device pack
http://www.cisco.com/web/software/282074289/23369/cmterm-7925-sccp.1-3-1-Readme.html
Hope this helps!
Rob
Happy holidays Rob,
You continue to amaze me with your patience and detailed responses. As always well deserved 5 points for you.
Chris
Hey Chris,
Thanks so much for your kind words my friend! They mean alot coming from a fellow NetPro whom I really admire.
Have a Rockin Festive Season.
Cheers!
Rob
Rob-
Thanks for your reply. When checking the software download site the latest version I see under
CUCM V 6 --> Device Packages is
6.0(1.3109)
Maybe its not released yet?
Aaron
The same thing applies to 6.1.2
Latest device pack for 6.1.2 is
6.1(2.1113)
7.0 doesn't have the listing for device packs as of yet.
Perhaps they will be released soon....considering the phones are shipping??
Hi Aaron,
Good call! I'm sure these Devpaks are right around the corner.
I would open a TAC Case and see if they can't setup a special file access for you if you need it ahead of time.
Hope this helps!
Rob
352
