Community Member
7925G Character limit
We need to know the maximum number of characters that could be displayed on the phone across the display (width), as well as the maximum number of rows down (# of vertical rows down) on the 7925G phone.
Does anyone know these answers?  A third party vendor will be sending us messages from there system to our 7925G's
1 REPLY
I don't know the answer, but it won't be a fixed number of characters when it comes to the width, as it depends on the characters. It's the same for any phone model, an I doesn't take the same space as an O to display.
You'll need to run some tests using those messages to get an aproximate of how many characters you'll get.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
159
