09-22-2013 12:33 PM - edited 03-16-2019 07:29 PM
I have problem sending multicast audio(mp3) to cisco phone 7925G, audio packets are not received by the phone, I found the following in the phone logs
15:42:50:0500 HERMIT authpriv.err AUD: MT:***RTP- No RX audio frame to DSP
2013-09-22 15:43:45:0870 HERMIT user.err GUI: **** err bat:0
I tried upgrade and downgrade the firmware version of the phone, also I tried disable G722 codec to force G711 codec, also I disabled bluetooth, but nothing worked, also I tried to send the same multicast traffic over the same wireless AP using CIPC on two labtops (using wireless) and the audio worked fine, can any one help me with this problem
Best regards,
Mostafa Haroun
08-27-2015 02:20 PM
I have faced similar issue related to multicast audio not working on the Cisco 7925g over wireless.
the reason in my case was due the settings in the Cisco wireless controller
802.11b/g Global parameters with Data Rates with minimum of 24Mbps as mandatory.
The conclusion is the 5.5 Mbps should be the minimum to be selected as mandatory because the Multicast packets when communicating over wireless operate at low Mbps.
02-23-2016 10:15 AM
hello kishork_1987
Can you tell me, which parameters you set in the WLC ? I have the same problem.
