Community Member
7925G No Sound
Hello everyone,
I work for a hospital and we have quite a few 7925g Cisco Wi-Fi phones.  For some reason one of our phones won't make sounds either while pressing keys or when someone calls.  I have all the sound options turned up and DND is not enabled.
My only guess is that the speaker itself has stopped working.  Any suggestions?
Thank you in advance
1 REPLY
7925G No Sound
Three options.
1) Try to do a firmware upgrade if not already done to rule out software issues.
2) Factory reste
3) If the above two do not work , it will need an RMA
Manish
149
