7925G verification steps after install on 2911 ISR/CME
  After configuring the 2911 in a lab environment, I need to verify the 7925G works but with no dialtone what can I do to ensure its configured/operating properly BEFORE I go onsite to install the 2911 ad 7925G?    Any 7925G simulator should I need to isolate problem to the CME configuration rather than the wireless or QOS setup? There must be some checklist to run in sequence after the install...right?
Everyone's tags (2)
Hall of Fame Super Gold
There is not. If it doesn;t work you will have to address problems onsite.
Re: 7925G verification steps after install on 2911 ISR/CME
                   What steps (checklist) can I follow to verify the install is correct (ie, dhcp, tftp accessible, wireless, qos issues, etc.)? It seems like there are endless issues that could arise so what is a process to begin to verify it is correct. Onsite is 5 states over so whatever 7925 simulator or checklist would be helpful.
192
作成コンテンツを作成するには してください
