7931 Features
Hi there !
I read 7931 have 24 buttons..
Are those buttons for monitoring only or is it possible to make them a speed dial button as well ?
Can they be both monitoring and SpeedDial in the same time ?
I did not find the Smartnet PN , witch one should I use ?
Thanks.
Andrei.
1 REPLY
Hall of Fame Super Red
Re: 7931 Features
Hi Andrei,
Just as a "heads up" the 7931 is only supported on CME and CCM 6.x (I know last time we spoke you were running CCM 4.2 :)
If you are using the 7931 with CME then the Buttons can be programmed in Monitor Mode which is also a DSS/Speeddial to the Monitored DN.
The Part#'s are shown in this doc;
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps7062/product_data_sheet0900aecd80534259.html
Hope this helps!
Rob
136
