7931 Ringtone
How do assign a different ringtone to my 7931? I can browse and assign using a 7941.. but obviously the 7931's are different..
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 7931 Ringtone
Hi Huw,
Good stuff my friend! I believe that button 24 should be the Menu access by default. Can you have a look here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1025832
Hope this helps!
Rob
Re: 7931 Ringtone
Hi Huw,
Nice to talk with you again!
Select the Ring Type
To change the ring type, use the following method:
1. Press line button 24 to access the Applications Menu key (default). If you are not sure of which button is configured as the Applications Menu key, use the Navigation button to display all button configurations.
2. Use the Navigation pad to choose Settings, or press keypad digit 3.
3. Press 2 for Ring Type, or use the Navigation pad to access Ring Type and press the Select button.
4. Use the Navigation pad to scroll through the list of ring types. Press the Play soft key to hear samples.
5. Highlight the ring you want, and then press the Select button.
6. Press the Save soft key to save the setting, or press Cancel to exit to the previous menu without changing the setting.
7. Press the Exit soft key to return to the main directory menu.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/ip_phones/7931/4.0/english/user/guide/ugKSsccp.html#wp38455
Hope this helps!
Rob
Re: 7931 Ringtone
Hi Bob,
You're in danger of making it onto my Christmas card list!
Cheers for that. I've taken a look and my line button 24 doesn't do much. I've tried my navigation pad but don't get anywhere either. Is there any command (via the command line or GUI) i need to enter to make button 24 acces the apps menu?
Re: 7931 Ringtone
Hi Huw,
Hope this helps!
Rob
Re: 7931 Ringtone
spot on. I created an ephone template and added the button layout set command. Works a treat.
Thanks!!
678
