7931G DLU!
hi, can anyone please provide me how many DLU does the Cisco IP Phone 7931G needs cause from this link it wasn't updated:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/ps6164/prod_qas0900aecd805009fc_ps556_Products_Q_and_A_Item.html
thanks for all
7 Replies 7
Brandon Buffin
Currently, the 7931G is only supported on Callmanager Express, not Callmanager, so DLUs do not apply. It will be supported on Callmanager in the future. See the following link.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps7062/prod_qas0900aecd80534289.html
Hope this helps. If so, please rate the post.
Brandon
Sorry Mr bbuffin but the IP Phone 7931G is supported by the CallManager 6.0 check the doc attached below it's CCM's datasheet
Interesting - these documents have conflicting information. I cannot find a DLU requirement for the 7931G. Sorry.
Brandon
thanks anyway i appreciate your help :)
I would highly recommend that you contact your sales team for these sorts of licensing questions. They will have the final word on this for you.
The 7931G is supported on CUCM 6.0 and later. It takes 4 units per device according to the calculator that I have seen.
Hope this helps,
Chris
just confirming on what chris said. The 6.0 calculator shows 4 DLUs per 7931G. i haven't found any documentation on this though.
