7936 rebooting
m.batts
Level 4
Level 4
I have couple of 7936's that keep rebooting in one of our offices.
I know they both work because of i move them to another office they work fine.
I have adjusted speed/duplex , removed the voice vlan and also updated to the latest code 3.3.12.
Any ideas
gogasca
Level 10
Level 10
At this point, I would say there is sth inthe netwrok which is causing the 7936 to lose connection to CCM.
If you increase keepalive it helps?
A detailed CCM trace and sniffer trace will help.
In CCM Event Viewer which the reason code for the IP Phone unregistration?
