7937 External mics causing crackling sounds on line
oscardawgg
Hey all,
I am having a issue with a 7937 we have in our network.  Its in a medium size conference room, and was hooked up with two external mics to provide maximum usage for conferences.  Problem was other users connected to conference reported heavy crackling sounds.  I checked out equipment and determined the mics were causing issue.  My question is, both mics are labeled B. Is there supposed to be a A and B mic?  or can you have two Bs with no issues?
Thanks for any info.
Oscardawgg
Risat
Level 3
Level 3
Hi Joshua,
As per my experience so far, you can connect any mics to the conference station. Did you just try connecting one mic and check the voice quality.
Riyas AT
