Community Member
7937 Power Requirements
Does the external mic kit require any additional power above the 802.3af Class 3 requirements, that the phone requires? I will be plug phone into a 3560, but was wondering if the additional mics required using the external power supply.
Thanks in advance for any help with this matter.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 7937 Power Requirements
Hi Trent,
The use of the External Mic Kit does not require any additional power. The ability to completely power the 7937 with just Class 3 PoE is one of the nice design features (no more spider-web of cables!)
Hope this helps!
Rob
Hi Trent,
Hope this helps!
Rob
Community Member
Thanks for the quick response
1009
