04-02-2009 11:53 AM - edited 03-15-2019 05:16 PM
Looking at the datasheet for this piece I see that support for CME "will be supported in the future". Is the future now? Will this work on a UC520 system running V4.2? Also, does the mic kit bring one mic or two? The picture shows two mics but the description of the actual kit is not clear.
Diego
Solved! Go to Solution.
04-02-2009 02:13 PM
Hi Diego,
Just to add a note to the great tips from Nick (+5 points here Nick :)
The Mic Kit does come with 2 external Mic's. I have one sitting in front of me right now (pretty cool looking little guys!).
Cheers!
Rob
04-02-2009 01:10 PM
Hi Diego,
You're probably looking at an older version.
We implemented some new commands in 12.4(15)XZ that allow for certain templates to be added that we used for the 7937.
On my 12.4(20)T2 router in the lab, the type command shows the 7937. Additionally, you can check the command reference on the 'type' command, it will tell you exactly where it went in.
But to be short, it's supported after 20T.
-nick
04-02-2009 06:49 PM
Just any image after 20T? What about the CME version or the fact that I am using a UC500 based box?
Diego
04-02-2009 09:54 PM
Hi Diego,
CME 7.0 is the CME version, which is 20T. CME version = IOS version, there's no way to change one without the other.
UC500 supports 12.4(11)XW code and any code 20T or later.
-nick
04-03-2009 03:51 AM
Cool, thanks. I guess I'll try to get to that 20T level.
Diego
04-02-2009 02:13 PM
Hi Diego,
Cheers!
Rob
