Bronze
7937 with CUCM6.12
Just install 7937 conference station with CUCM6.12. Everything seems fine, except I don't see "Corporate Directory".
Anyone can point me to right direction.
Ken
Re: 7937 with CUCM6.12
Have you subscribed the device to the relevant directory ?
Bronze
Steel,
I don't know what you mean "relevant directory"?
Ken
Hall of Fame Super Red
Hi Ken,
Don't know if this helps at all but I just wanted to let you know that the Corporate Directory is working on a 7937 that I just tested (not on CCM 6.1(2)) It did not come up on the initial "Directories screen" as it is choice # 5 so you have to scroll down a bit.
Hope this helps!
Rob
Bronze
Hi Rob,
Nice to hear from you again.
I knew what you mean, but I press the button, I see 4 options, but don't see choice #5. It is so weird.
I guess I am going to contact tac.
Ken
Hi guys we are seeing the same thing, the 7937 seems to use a diffrent browser from the standard phone, it also looks like it times out. The phone software is on 1.2(1) and the bootrom is 1.0. Was going to check if there where any firmware updates. will update once i have checked.
We are also on 6.1(2)
174
