Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
7940 Configuration issue
Hi was wondering if any one can help configure a 7940 IP to the service network we are using in the uk which is soho66.  We have connected the phone via a router.  Its running on SIP software and we have entered the network access details onto the SIP configuration Line 1 function I.e. user names, passwords and have entered the proxy address sip.soho66.co.uk and set the proxy port 8060.
According to our provider that should work but we have not altered any of the network setup settings on the settings menu 3.
We have a dail tone after the phone boots up but there is a telephone symbol displayed in corner with a X next too it.
Any ideas where we are going wrong or what we could be missing. thanks
Everyone's tags (3)
Re: 7940 Configuration issue
X mark next to the button/line indicates that its is not registered
with the SIP proxy.
From the phone menu (SIP Config) or .cnf file you need to point it
to the proxy/port. Do you have a name server (DNS) configured under
network settings if u r using proxy name and not IP ?
You can telnet/ssh to the phone's IP and ...
show register
sh config
enable deb sip-mess
DNS server setting settings set as 192.168.0.1.  And my phones IP address is 192.168.0.5 so what do i have to do as I don't fulliy understand what you mean by
show register
sh config
enable deb sip-mess.  "
Sorry to sound dumb.  thanks Harjinder
i'm using the proxy address sip.soho66.co.uk and the proxy port 8060. if that helps thanks Harjinder
Can u ping sip.soho66.co.uk from 192.168.0.1 ?
7940/60 phones have CLI interface that let's u monitor/troubleshoot, please see:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp7960/addprot/sip/admin/8_0/siptrb75.htm#wp998605
These phone use a config file SIP.cnf where you can populate all the relevant parameters.
You should also take a look at following site which is Asterisk specific but has tons of
good info on configuring and troubleshooting these phones.
http://www.voip-info.org/wiki/view/Asterisk+phone+cisco+79xx
1342
