Community Member
7940 Firmware Compatibility
I am upgrading my cucm from 6.1.3 to 7.1.5, at present my7940 phones are using firmware P0S3-08-11-00/P00308010100 will I able to use the same firmware after the upgrade. As most of my phones is in remote site and will take my WAN for downloading the Firmware from CUCM
Is P0S3-08-11-00/P00308010100 firmware compatible with 7.1.5?
Re: 7940 Firmware Compatibility
Yes you can use older firmware with the phones with CUCM 7.1.5 it will work due to backwards compatibility but you may not be able to use new features that are available in CUCM 7.1.5.
Community Member
Thanks for the information
Hall of Fame Super Red
Hi Surjit,
Just to add a note to the great tips from Joe (+5 Joe!)
The existing firmware will work but you will need to take precautions to prevent the phones from trying
to upgrade their Firmware during the upgrade of CUCM to 7.1(5)
The default firmware for the 7940's  within 7.1(5) is shown below;
Cisco Unified IP Phone 7940G - SCCP
cmterm-7940_7960-sccp.8.1.2.cop.sgn
Check out Table 19
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43813
There are some excellent tips from Bill Bell in this thread
https://supportforums.cisco.com/thread/2015221
Cheers!
Rob
Excellent point Rob, that's something you don't want to forget or over look!  Thanks adding that.
Community Member
Thanks for the info
1310
