7940 has wrong ip address
i have a 7940 that will not register with ccm. this is a new office install so there are no other phones that work. the phone is stuck on "configuring cm list". the phone has worked in another office on a different subnet. i noticed during the boot process it says "opening 192.168.140.1" when the subnet is 192.168.153.1. i released the dhcp address, erased config. i have the data netowrk working great. i think the issue is in the switch config - i'll attach config.
thanks in advance
Bronze
Re: 7940 has wrong ip address
Happened to me already with same type of scenario where i moved the phone to a new location. however, mine was easily fixed by resetting the phone to factory defaults. if this as you say did not work, disable dhcp and set the phone with a static ip, manual gateway etc.
if that works, then set back to DHCP.
Hope this at least helps
i figured it out - it appears i left out some dhcp config (default-router x.x.x.x). i also enabled cdp on the phone vlan interface.
thanks for the reply!
251
