7940 IP Phone wont register to CME 8.6, in loop.
Geo Gon
I have 2 7940 phones that just wont register, they keep going round in a loop.
Im using a 3550 layer 3 switch as dhcp and a 2801 CME 8.6 router.
Please take a look on the configs:
ROUTER:
Current configuration : 8211 bytes
! Last configuration change at 23:42:52 BST Mon Aug 6 2012
version 15.1
service password-encryption
hostname R2800
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone GMT 0 0
clock summer-time BST recurring
dot11 syslog
ip source-route
--More--                           !
ip cef
ip name-server 4.2.2.2
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
sip
  registrar server expires max 600 min 60
--More--                           !
voice-card 0
crypto pki trustpoint TP-self-signed-875489979
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-875489979
revocation-check none
rsakeypair TP-self-signed-875489979
crypto pki certificate chain TP-self-signed-875489979
certificate self-signed 01
  3082023B 308201A4 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 38373534 38393937 39301E17 0D313230 38303631 37323530
  375A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3837 35343839
  39373930 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  D2E85DBD F324311E 4691B2D2 C81B3A6F 25A82E33 3A46A3FA 244C50B0 DED9901D
  E4CE5523 77D56F48 C8634BE0 011013E8 9A2D1560 AF22068E 34F905A7 929D28B6
--More--                             9653175C A24B1E4D 301DAC18 E0244636 10192D31 2860DEA8 CB00D314 B020E30F
  3AD207B4 170553AB 4D2188AA C37AF296 9C23A7F6 83BDA5FF 0644D320 5988F35D
  02030100 01A36530 63300F06 03551D13 0101FF04 05300301 01FF3010 0603551D
  11040930 07820552 32383030 301F0603 551D2304 18301680 149FF075 EF5A5FD9
  44F9B17F F0A2D4C1 0C767A46 61301D06 03551D0E 04160414 9FF075EF 5A5FD944
  F9B17FF0 A2D4C10C 767A4661 300D0609 2A864886 F70D0101 04050003 81810051
  A6CEDB53 4CCDF403 DA66E8F1 ED5D9219 1CC2C63C 04FABC74 79BD427A E77DF192
  75698714 91F3ED90 028A805F 1053C08F 4571B8EA BAA01378 6D1D81F3 87904837
  BAA6B08C 7D75780F C9BFC421 EAC10D66 F918B7E8 69BF1F34 6C6572BB 327B135B
  DDAB16ED 0DE61C19 39D95523 87D4A6AD 3ED10F66 DAEA3AC0 3C23B02E 3B5EF2
       quit
license udi pid CISCO2801 sn FHK085210WV
archive
log config
  hidekeys
redundancy
interface Loopback0
ip address 172.31.100.100 255.255.255.0
interface FastEthernet0/0
ip address 172.20.0.2 255.255.0.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.5.2 255.255.255.0
duplex auto
speed auto
interface Serial0/2/0
ip address 172.18.0.2 255.255.255.252
--More--                            no fair-queue
interface Serial0/2/1
ip address 172.19.0.2 255.255.255.252
router eigrp 1
network 172.16.0.0
network 172.17.0.0
network 172.18.0.0
network 172.19.0.0
network 172.20.0.0
network 172.21.0.0
network 172.26.0.0
network 172.31.0.0
auto-summary
ip forward-protocol nd
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.5.1
--More--                           !
tftp-server flash:P0030801SR02.bin alias P0030801SR02.bin
control-plane
mgcp profile default
dial-peer cor custom
name 888call
name localcall
name internationalcall
name mobilecall
name chargenumbers
dial-peer cor list EMERGENCY
--More--                            member 888call
dial-peer cor list LOCAL
member localcall
dial-peer cor list MOBILE
member mobilecall
dial-peer cor list INTERNATIONAL
member internationalcall
dial-peer cor list CHARGENUMBERS
member chargenumbers
dial-peer cor list MOLOEM
member 888call
member localcall
member mobilecall
dial-peer cor list ALL
member 888call
member localcall
member mobilecall
--More--                            member chargenumbers
dial-peer voice 1 voip
description Dial peer to ext on 2600
destination-pattern 600.
session target ipv4:172.18.0.1
dtmf-relay h245-alphanumeric
codec g729br8
dial-peer voice 11 voip
preference 1
session target ipv4:172.17.0.2
codec g729br8
dial-peer voice 2 voip
corlist outgoing MOBILE
description Dial peer to UK mobiles
destination-pattern 907[1-9]........
incoming called-number 0000000000
--More--                            dtmf-relay h245-alphanumeric
codec g729br8
dial-peer voice 22 voip
preference 1
codec g729br8
dial-peer voice 3 voip
corlist outgoing LOCAL
description Dial peer to UK landline
destination-pattern 90[1-2].........
incoming called-number 0000000000000
codec g729br8
dial-peer voice 33 voip
--More--                            preference 1
codec g729br8
dial-peer voice 4 voip
corlist outgoing INTERNATIONAL
description Dial peer to international
destination-pattern 900T
codec g729br8
dial-peer voice 44 voip
preference 1
codec g729br8
--More--                           dial-peer voice 844 voip
corlist outgoing CHARGENUMBERS
description Dial peer to 0844 numbers
destination-pattern 90844.......
codec g729br8
dial-peer voice 844844 voip
description Dial peer to 844 numbers
preference 1
codec g729br8
dial-peer voice 911 voip
description Dial peer to 0911 numbers
destination-pattern 90911.......
codec g729br8
--More--                           !
dial-peer voice 911911 voip
preference 1
codec g729br8
dial-peer voice 5 voip
corlist outgoing EMERGENCY
description Dial peer to emergency
destination-pattern 888
codec g729br8
dial-peer voice 55 voip
preference 1
--More--                            codec g729br8
num-exp 0 5002
telephony-service
max-ephones 20
max-dn 40
ip source-address 172.31.100.100 port 2000
timeouts ringing 15
cnf-file location flash:
network-locale GB
load 7960-7940 P0030801SR02.loads
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
moh piano1.raw
web admin system name geovani secret 5 $1$/bdX$.dVoJQyULiTg3gitqqku7/
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Aug 06 2012 23:42:52
--More--                           !
ephone-dn  1  dual-line
number 5001
pickup-group 6666
label Geovani 5001
description phone
name Geovani Goncalves
call-forward busy 5002
call-forward noan 6001 timeout 18
corlist incoming MOLOEM
hold-alert 15 originator
ephone-dn  2  dual-line
number 5002
pickup-group 6666
description Matheus
name Matheus Guedes
corlist incoming EMERGENCY
ephone  3
device-security-mode none
mac-address 60EB.69F5.72B4
--More--                            button  1:1
line con 0
exec-timeout 0 0
password 7 110A1016141D4B
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password 7 01100F175804
login
transport input telnet ssh
scheduler allocate 20000 1000
ntp master
ntp server 194.35.252.7
ntp server 66.27.60.10
ntp server 200.50.25.62
end
SWITCH:
Current configuration : 7092 bytes
version 12.2
no service pad
hostname S3550
no aaa new-model
authentication mac-move permit
ip subnet-zero
ip routing
no ip domain-lookup
ip dhcp excluded-address 172.21.1.1 172.21.1.20
ip dhcp excluded-address 172.21.1.100 172.21.1.150
--More--                           ip dhcp excluded-address 172.21.5.1 172.21.5.20
ip dhcp excluded-address 172.21.5.50 172.21.5.100
ip dhcp excluded-address 172.26.10.1 172.26.10.20
ip dhcp excluded-address 172.26.5.1 172.26.5.20
ip dhcp pool Vlan100Voice
   import all
   network 172.21.1.0 255.255.255.0
   default-router 172.20.0.2
   dns-server 4.2.2.2
   option 150 ip 172.31.100.100
ip dhcp pool Vlan50Data
   import all
   network 172.21.5.0 255.255.255.0
   dns-server 4.2.2.2
ip dhcp pool Vlan10Voice
   import all
   network 172.26.10.0 255.255.255.0
   default-router 172.25.0.2
   dns-server 4.2.2.2
--More--                           !
ip dhcp pool Vlan5Data
   import all
   network 172.26.5.0 255.255.255.0
   dns-server 4.2.2.2
crypto pki trustpoint TP-self-signed-605573248
subject-name cn=IOS-Self-Signed-Certificate-605573248
rsakeypair TP-self-signed-605573248
crypto pki certificate chain TP-self-signed-605573248
  3082023C 308201A5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  69666963 6174652D 36303535 37333234 38301E17 0D393330 33303130 30303130
  305A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
--More--                             532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3630 35353733
  32343830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  D74F45E5 0E1DA0CF A469A89D 99C572F2 9DEF1211 7FA134BD 98128F8C 61B99069
  8C5E9C96 D3C93EF1 57D3EC2C 8BCAA39E 0A15ED48 1C1775C3 D7ABAC73 86327F4C
  76F2D11C 68E6F22E 6EC039AE 1DF9E7DD 405178AA 916003C3 72122E50 C6309718
  4D50EC65 9DE4E252 A0D8E6BF 99B46572 C6E23A66 93FAC298 821A736B 6BC2E893
  02030100 01A36630 64300F06 03551D13 0101FF04 05300301 01FF3011 0603551D
  11040A30 08820653 33353530 2E301F06 03551D23 04183016 80149AD6 0FFC542F
  7086A508 37405942 5B2C1511 7CFB301D 0603551D 0E041604 149AD60F FC542F70
  86A50837 4059425B 2C15117C FB300D06 092A8648 86F70D01 01040500 03818100
  CAEEBD0D 93A6B508 8B012F6A BAEC7F1A 2CCF8030 705B1938 895B937C B471E477
  8D62ADC5 BA5F9AEA 62541E03 4EFA0F29 57636502 0B606BD0 CB219B56 4233A6B8
  803A4E2E A080D6FF AEF715E9 D850FE69 432914CE E4DD91AE F10A6D2E E35E474B
  74DEF808 F67CA3F4 DF06A65E 2E09EA44 6996B3B6 5932D6A1 FEB34D44 3DE2B9BA
  quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface Loopback0
ip address 172.31.10.10 255.255.255.0
no switchport
ip address 172.25.0.3 255.255.0.0
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 5
switchport mode access
switchport voice vlan 10
interface FastEthernet0/3
--More--                            spanning-tree portfast
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
--More--                            switchport voice vlan 10
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
--More--                            switchport mode access
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 50
switchport voice vlan 100
interface FastEthernet0/14
interface FastEthernet0/15
--More--                            switchport access vlan 50
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
--More--                           interface FastEthernet0/19
interface FastEthernet0/20
switchport mode dynamic desirable
interface FastEthernet0/21
interface FastEthernet0/22
--More--                           !
interface FastEthernet0/23
interface FastEthernet0/24
no switchport
ip address 172.20.0.3 255.255.0.0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan5
ip address 172.26.5.5 255.255.255.0
--More--                            ip helper-address 172.25.0.2
interface Vlan10
ip address 172.26.1.10 255.255.255.0
interface Vlan50
ip address 172.21.5.50 255.255.255.0
interface Vlan100
ip address 172.21.1.100 255.255.255.0
router eigrp 1
network 172.16.0.0
network 172.17.0.0
network 172.18.0.0
network 172.19.0.0
network 172.20.0.0
network 172.21.0.0
network 172.26.0.0
network 172.31.0.0
--More--                           ip classless
ip route 0.0.0.0 0.0.0.0 172.20.0.2
ip http server
ip sla enable reaction-alerts
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
exec-timeout 0 0
password cisco
logging synchronous
login
line vty 5 15
login
end
--More--
Can you please help me out to figure out what's wrong?
Not weird, this is wrong.
default gateway must be always within subnet.
10 Replies 10
paolo bevilacqua
What the phone shows? Do they have SCCP fimrware ?
You can take "debug tftp events" to begin with.
Hi Paolo,
When telneted into the router, I've tried to debug the tftp events, but nothing came up.
When the phones are powered on, it shows all the steps but it goes on a loop.
The phones are able to pick up an ip address and all the network configuration.
Note that when I point a CIPC to the tftp it register and works fine.
thanks again
Have "term mon" with any debug command.
If you don't see output, means no or wrong option 150 in DHCP.
Thanks Paolo again.
Will try it tomorrow.
Does my layer 3 switch and router looks ok to you? Can you see anything wrong?
Not sure what can go wrong with option 150, as long as it is pointing to the right tftp server, and in this case it is.
Paolo,
I have tried using "term mon" with "debug tftp" but nothing came up.
Any other ideas?
The option 150 is on and the phone is picking up the tftp address.
With the browser, open phone IP address and check logs, may that will reveal something.
Thanks Paolo,
I cannont access the phone using the browser and i cant ping it neither.
I have just reverted everything back as it was, using rounter on the stick, and the phones are registering just fine.
Weird.
Bang on Paolo, many thanks for your help.
It's all working now.
Thank you for the nice rating and good luck!
