Community Member
7940 Phone not finding it's tftp file even though it's there
I'm trying to update the .bin file on my 7940 ip phones but debugs show it just keeps looking for the file....
*Sep 10 17:10:19 UTC: TFTP: Sending block 1 (retry 0), socket_id 0x49BA0B70
*Sep 10 17:10:19 UTC: TFTP: Received ACK for block 1, socket_id 0x49BA0B70
*Sep 10 17:10:19 UTC: TFTP: Sending block 2 (retry 0), socket_id 0x49BA0B70
*Sep 10 17:10:19 UTC: TFTP: Received ACK for block 2, socket_id 0x49BA0B70
*Sep 10 17:10:19 UTC: TFTP: Finished system:/its/XMLDefault7940.cnf.xml, time 00:00:00 for process 126
ce-us-san-ifx001#
*Sep 10 17:10:23 UTC: TFTP: Server request for port 49205, socket_id 0x49BA0B70 for process 126
*Sep 10 17:10:23 UTC: TFTP: read request from host 10.10.66.3(49205) via GigabitEthernet0/0.666
*Sep 10 17:10:23 UTC: TFTP: Looking for P00308000500.bin
ce-us-san-ifx001#
*Sep 10 17:10:27 UTC: TFTP: Server request for port 49205, socket_id 0x49BA0B70 for process 126
*Sep 10 17:10:27 UTC: TFTP: read request from host 10.10.66.3(49205) via GigabitEthernet0/0.666
*Sep 10 17:10:27 UTC: TFTP: Looking for P00308000500.bin
I have it configured like this:
tftp-server flash:P00308000500.bin
And..
show flash
98 0 Aug 03 2009 21:57:38 phone/7940-7960
99 129824 Aug 03 2009 21:57:38 phone/7940-7960/P00308000500.bin
100 458 Aug 03 2009 21:57:38 phone/7940-7960/P00308000500.loads
101 705536 Aug 03 2009 21:57:42 phone/7940-7960/P00308000500.sb2
102 130228 Aug 03 2009 21:57:44 phone/7940-7960/P00308000500.sbn
The phones DO get ip addresses when checking from the phone but when I do a show ephone it shows:
ephone-1[0] Mac:0017.E0F0.B868 TCP socket:[-1] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0 0 Unknown 0 keepalive 0 max_line 0
Preferred Codec: g711ulaw
Please help!
Re: 7940 Phone not finding it's tftp file even though it's there
You need this command:
tftp-server P00308000500.bin alias flash:/phone/7940-7960/P00308000500.bin
you can keep adding aliases for each of your files.
-nick
Hall of Fame Super Gold
Move all firmware files to root directory on flash.
Remove all tftp-server commands.
Configure under telephony-service:
cnf-location flash:/
load 7960-40 P00308000500.loads
Note the .loads is specified for the new automatic mode.
1129
