7940 Phone Unregisters/Drops Calls on IPSEC VPN
We have an IPSEC 3DES VPN L2L tunnel between an ASA5520 and a 851 router. The phone connected to the 851 frequently unregisters with the CM and or reboots. The fixup protocol is enabled for skinny port 2000 on the ASA.
All other data connections on the vpn tunnel work fine. Any ideas what would cause the phone problems?
Green
Re: 7940 Phone Unregisters/Drops Calls on IPSEC VPN
Normally this is Phone load problem or network issue.
Please make sure you are using latest phone load and you may try increment keepalive timer in CCM.
Check EV to see reason of Unregistration.
Okay the EV shows the phone is frequently getting DeviceTransientConnection error events, however I was able to do directory name searches while the phone shows "CM down, features disabled" which tells me the VPN tunnel is working correctly for HTTP. What ports does a phone use to register with the CM and how/where do I change the increment keepalive timer in CM (4.1.3)?
Also, we are running the latest firmware for the 7940 phone in question (P0030800400)
Green
Port TCP 2000 for Skinny protocol.
CCMAdmin | Service | Service Parameters | Cisco CallManager |
Station KeepAlive Interval :
This parameter designates the interval between KeepAlive messages sent from Cisco IP
Phones to the primary Cisco CallManager.
This is a required field.
Default: 30.
Unit: sec.
Minimum: 10.
Maximum: 1000.
Station and Backup Server KeepAlive Interval : This parameter designates the interval
between KeepAlive messages that are sent from Cisco IP Phones to the secondary Cisco
CallManager.
Default: 60.
Unit: sec.
Minimum: 10.
Maximum: 1000.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a008071577c.html#wp1024704
315
