7940 Phone with Logo/Watermark
I am trying to figure out how to setup a watermark or logo-background on a 7940. I have configured the Idle image, but I need to see the line extensions this covers up. I am currently using CCM4.1, but upgrading to 4.3 shortly.
Re: 7940 Phone with Logo/Watermark
that thread is only for 7970s, the procedure does not apply to 7940s due to the resolution and screen size not being the same
think you already have this:
Creating Idle URL Using Graphics on Cisco IP Phone
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801c0764.shtml
you can check this page:
http://www.ccmstuff.net/
there are some services that show images and might be what you're looking for
java
if this helps, please rate
www.cisco.com/go/pdi
This answeres my question, we can't have a true wallpaper/watermark on a 7940. I'll just stick with the Idle pic and hope for an upgrade or my company to buy a thousand 7970s!
Thanks for the help.
actually you can have a wallpaper in 7941's and 7961's also
of course it's not as fancy as a nice colored big screen as with the 797Xs but you can also configure a background for those models
less resolution and only grey-scale but it's an option
java
529
