7940G and 7960G not registering
Hello, I have just updated a cucm 7.1.3.10000-11  to a 7.1.3bSU2 and now the models 7940G and 7960G are not registering.
Im getting this error TFTP General Error File Auth Fail: DISTINCTIVERINGLIST.XML.sgn , but everuthing else is working fine, any suggestion?
Re: 7940G and 7960G not registering
Try deleting the CTL file from the phone manually by going through Settings and register it again.
regards
Sriram
Would it be possible to attach snippet directly from the phone's debug display?  I am not finding anything specific about the error you're experiencing, just want to make sure its exact.
You can go there by browsing to the phone's IP address and selecting the link at the side that says "Debug Display".
--Matt
I have not been able to collect any data from that error either, its on a customer site, so i will request it,
actually a believe that have something to see with the firmware version that the new deploy tries to load, but its just a though, i will post the info as sonn as i got it
thanks for the help!!!!
Depending on what version you upgraded from you could be falling victim to the two-step firmware upgrade problem, described here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_3/english/release/notes/7900_853.html#wp57602
Can you tell what firmware the phones had pre-upgrade and what the current device defaults are?
If these are 7940/60 phones they wouldn't be running that firmware.  That issue is specific to 3rd gen phones.
--Matt
I am assuming these are secure phones, so have you tried to re-run the CTL client to ensure that the TFTP server in question is in the authorized list of servers?
--Matt
First at all, thanks a lot for all your responses,
The phones are not secured, at least until we have this issue fixed, the 7960, was working before the upgrade it was running the firmware version 8.0(5.0) and now the call manager is trying to upgrade it to de version P00308010200
and i got the error message confirmed, im sorry but im in spain, so the messages are in spanish
first one , the 7960
General TFTP error
SEP00131A6ECF35.CNF.XML.SGN
file autentication error : DISTINCTIVERINGLIST.XML.s
second one, the 7940
General TFTP error
file authentication error : SEPxxxxxxxx.cnf.xml.s
thanks again
Cesar
Hi all, its a bug
CSCtd84665
and its solved upgrading to 8.1(1), and after that 8.2(2)
thaks for your time anyway
cesar
2088
