7940G and Expansion Module 7914
The expansion Module 7914 can Work with IP Phone 7940G?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 7940G and Expansion Module 7914
Hi William,
Ajaz is correct :) Mant people have tried this setup over the past few years but it will not work. Have a look towards the end of this doc (I believe the 7914 is only compatible with 7960,7961,7970,7971);
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a008066e11e.html
Hope this helps!
Rob
Silver
according to this data sheet on the 7914, it would appear not to be supported.
hth,
Ajaz
Hi William,
Hope this helps!
Rob
174
