Community Member
7940G reset when ping -l
when ping 7940G -l 1500,7940G appears reset;how can fix it?
fyi: 7912G has not the problem.
Super Bronze
Re: 7940G reset when ping -l
Download the latest Device Pack for your version of CCM, and apply it as directed in the readme (i.e. to all servers in your cluster - starting with the Publisher, then TFTP, then other subs).
It's most likely a bug with the phone firmware.
Or stop pinging it :-)
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Hi,we use
CME 4.1.0.2 (Compatible with IOS 12.4(15)T)
and
tftp-server flash:P00308000500.sbn
tftp-server flash:P00308000500.bin
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sb2
can you give me the bug id?
or how cah I upgrade to?
Community Member
upgrade the 7940 to P00308010100,fix the problem.
287
