7941 IP Phone cant be powered On
Suddenly one of my Cisco 7941 Phone didnt want to power anymore.
I tried facatory dedefault reset , Reboot  many times ,the only light is green is the Speaker button. Screen is completely blank
i tried different Ethernet ports , etc.
Any suggestion ?
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Post the output to the command "sh power inline".
Hall of Fame Super Silver
Re: 7941 IP Phone cant be powered On
Sounds like it's bricked and will need to be replaced.
Chris
Need more info.
Where does this phone draw it's power from.  If it's from a power brick of power injector, replace all.  This includes the power brick, injectors and also the CABLES.
If it's PoE, then go to the switch and post the output to the command "sh power inline ".
Hi Leo,
it is PoE  , I have a 2911 Router.
How will be the procedure to check the PoE?
THanks
2911Router:
tokvoice01(config)#sh power inline
% Invalid input detected at '^' marker.
tokvoice01(config)#exit
tokvoice01#sh power inline
doesnt give me any output.
-This is the ephone that is not powering:
ephone-4[3] Mac:0021.5504.63DB TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0* 0 Unknown 0  keepalive 0 max_line 0 available_line 0
button 1: cw:1 ccw:(0 0)
  dn 4  number 2704 CH1   IDLE         CH2   IDLE
button 2: cw:1 ccw:(0 0)
  dn 75 number 1010 CH1   DOWN         CH2   DOWN
Preferred Codec: g711ulaw
VIP Purple
Hi Victor,
You are trying to run the command on router.
You need to provide the output from POE switch or you are running POE module on router if any. please share show inventory/show diag
also, share output of show cdp neighbours details from switch/router
regds,
aman
the router is connected to a Juniper Switch , it seems that it is from the switch  where the Router has its power.
Although  all ports are work accordingly . I have tested in another LAN ports but phone doenst work. I dont have the Power adaoter for the unit( just relying on POE)
Hope that the output below helps
tokvoice01(config)#do show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
se-10-60-20-11   ISM0/0             153              H    ISM-SRE-3 Gig  0
tokvoice01(config)#
tokvoice01(config)#do show inventory
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9      , VID: V04 , SN: FGL154511FP
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FOC16030S8Q
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC15405MAL
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC16055PUU
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "Internal Services Module with Services Ready Engine"
PID: ISM-SRE-300-K9    , VID: V02 , SN: FOC16041RTN
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V03 , SN: AZS154205WD
Your router does not have PoE.
PS:  Please don't post screenshots.  Just copy and paste the output.
VIP Purple
Hi Victor,
I think u need to go as per Chris suggestions.
Router has its own power supply unit to get powered ON while phones are dependent on Juniper POE module.
regds,
aman
264
