Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
7941 speed dial problem!
Hi experts,
I got a user whose profile in CCM is 7941 and logged in 7941 unit. When config with speed dial, it don't appear. However when tired to login to another unit say 7960, it appears. Tried it myself & it works on 7960 but not on 7941.
Any related bugs?
thanks
1 ACCEPTED SOLUTION
Re: 7941 speed dial problem!
Check the phone button template of 7941. Is it 1 line + 1 speed dial. In this case you will get one speed dial to configure.
Also, are you trying to configure using ccmadmin or ccmuser
The template is set to "Standard 7941". After setting it to line 1, all is good.
configuring on the user logon web
thanks
211
