7941 Stuck in Upgrading
I have recently change from CCME 4.1 up to
8.0 and was having an issue with a 7941 phone load.  Thought was to factory reset the
unit so that it pulls the latest load form the CCME term41.default.loads.
The factory reset procedure works fine but when it goes to reboot I get the following:
1)MAC address shows up
2)Upgrading prompt shows up
3)Pulled DCHP address shows up
4)Phone stuck in Upgrading
The unit gets its DHCP address from the CCME router but never asks for the term41.default.loads.
I have packet sniffed teh line adn once teh DHCP handoff is made no other traffic comes from the phone other that a semi periodic CDP push.
Any thoughts?
Alex
Green
Re: 7941 Stuck in Upgrading
Are you going to upgrade the load?
From which version to which version?
Can you upload the packet capture so I can take a look
Also check TFTP debug
Just left the office for a week of vacation.
Phone was at 8.2(1) and with CCME 8.0 the upgrade goes to 8.5(4)
As far as the capture goes, there is not much to see.  I will attach it when I can.  I have had debug tftp events on and nothing from that and it is also the same on wireshark...nothing.  When a working phone is reset, I do see the TFPT debog login prompts show up.
One strange item:
I disabled the router at the DHCP sever and used tftp32 as my laptop with Option 150 turned on.  With wireshark on, I could see the 7941 broadcasting a DHCP request and tftp32 answering....but the 7941 would ignore the response and keeps broadcasting a DHCP request.  When I turn the DHCP back on in the router, the 7941 gets its address but stops doing anything once the address is received.  It seems almost as if the phone is not recognizing its TFTP server address and never starts requesting its default load.
Hall of Fame Super Red
Hi Alex,
Have you tried a pre 8.5.2 firmware?? To get to 9.x or 8.5.3 (4) you must
step through 8.5.2
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 8.5(2)SR1 or greater, you must first upgrade your firmware to version 8.5(2). Once you have upgraded to version 8.5(2), you can upgrade your IP Phone to version 8.5(2)SR1 or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_2/english/release/notes/7900_852SR1.html#wp164599
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Rob,
Have been trying to reload a pre 8.5.2 load.  For what ever reason, the phone does not boot properly and never tries to TFTP to the server.  Maybe when I plugged it into the upgraded system without going through the 8.5.2 load, the upgrade process screwed up something within the phone boot sequence.
1777
