Community Member
7942 boot load is missing
Hi All,
There is a problem.
I did a hardreset on IP phone 7942, and the boot code was wiped from the phone.
I have seen on another iphone that it has tnp42.8-3-1-21a.bin boot load.
How can I upload boot load to 7942 IP phone, and where can i find this file?
Regards:
Peter
Hall of Fame Super Gold
Re: 7942 boot load is missing
Boot load is not available separately from firmware files, and you do not need to worry about it.
You follow a normal firmware recovery procedure, and the phone will start working again.
Community Member
I have a CME 4.1. And i cant use exe and cop.sgn file to CME.
Could you ples help me?
Peter
There is a .zip version in the same place where .cop and .exe are accessed.
Update CME when possible, you are loosing a lot of features with that ancient one.
Community Member
in zip file  there is not boot load bin file like tnp42.8-3-1-21a.bin
Please read again my first post above, and trust who has experience in the subject.
391
