7942 Phones connecting to a CME router via SSL VPN wont register
Hi all,
I am having a problem in registering our 7942 phones to our CME router via SSL VPN. The IP phones can get the IP address from the SSL VPN (but lasts only for a couple of seconds) but it seems that the SSL VPN connection is not stable that it keeps on connecting and disconnecting. Below is the configurations I used to configure SSL VPN.
webvpn gateway sslvpn_gw
ssl trustpoint cme_cert
ip address X.X.X.X port 443
ssl encryption 3des-sha1 aes-sha1
http-redirect port 80
inservice
webvpn context sslvpn_context
ssl authenticate verify all
policy group SSLVPNphone
  functions svc-enabled
  svc address-pool "SSL-POOL" netmask 255.255.255.0
  svc default-domain "domain.com"
default-group-policy SSLVPNphone
aaa authentication list phoneVPN
gateway sslvpn_gw
inservice
voice service voip
vpn-group 1
   vpn-gateway 1 https://X.X.X.X/SSLVPNphone
   vpn-trustpoint 1 trustpoint cme_cert leaf
  vpn-profile 1
    host-id-check disable
ephone 2
vpn-group 1
vpn-profile 1
exit
telephony-service
create cnf
  • IP Telephony
196
