7942g kx-ncp500 not transferred call
7942g excellent call with ncp500, but then i need transfer to another telefone number nothing happen.
I can hold a call, even when the push transfer the first line hangs and I can return to it after talking on the other line. But transfer i can. I push transfer button twice, i try hang up but call is rejected.
Panasonic service told me that PBX in the SIP understands only re-invite command.
Is it possible to configure the phone to try?
Everyone's tags (2)
Hall of Fame Super Gold
Cisco does not support their phones with third party POBX. So if somethign doesn;t work, you're on your own.
I found a solution to the problem. Maybe it will help someone.
Panasonic NCP\TDE PBX does not understand the signal "transfer" .So you need to press "hold" and then make a second call and hang up after the response.
In this case, the call is transferred.
245
