7942G Phone VPN Authentication Issues
I have followed all of the documentation located here:
https://supportforums.cisco.com/docs/DOC-9124#/
I already have the AnyConnect client working properly. I have attempted to set up the phone connection using certificate authentication. I am using a seperate group policy with tunnel-all on it. DTLS is enabled. These are the messages that I am getting:
Status - 10:00:02a All Concentrators Failed
Phone - VPN Authentication failed.
Console Log -
8892: DBG 10:00:02.171244 VPNU: State AppsUp --> AppsUp
8893: DBG 10:00:02.171840 VPNU: SM wakeup - chld=0 tmr=0 io=1 res=0
8894: DBG 10:00:02.172428 VPNU: State AppsUp --> AppsUp
8895: NOT 10:00:02.180217 VPNC: vpnc_control: sending login cmd
8896: NOT 10:00:02.180958 VPNC: set_login_timer: timer set --> 30 sec
8897: NOT 10:00:02.181702 VPNC: protocol_handler: got login command
8898: NOT 10:00:02.182244 VPNC: set_login_state: LOGIN: 0 (NONE) --> 1 (TRYING)
8899: NOT 10:00:02.182771 VPNC: set_login_state: VPNC : 0 (Idle) --> 1 (LoggingIn)
8900: NOT 10:00:02.183351 VPNC: do_login: URL -> https://vpn.xxx.com/phone
8901: ERR 10:00:02.225875 VPNC: GETHOSTBYNAME: system problem with herror:1
8902: ERR 10:00:02.226512 VPNC: parse_url: gethostbyname failed <vpn.xxx.com>
8903: ERR 10:00:02.227056 VPNC: do_login: parse URL failed -> https://vpn.xxx.com/phone
8904: NOT 10:00:02.227575 VPNC: vpn_stop: de-activating vpn
8905: NOT 10:00:02.228072 VPNC: vpn_set_auto: auto -> auto
8906: NOT 10:00:02.228567 VPNC: vpn_set_active: activated -> de-activated
8907: NOT 10:00:02.229068 VPNC: set_login_state: LOGIN: 1 (TRYING) --> 3 (FAILED)
8908: NOT 10:00:02.229590 VPNC: set_login_state: VPNC : 1 (LoggingIn) --> 3 (LoginFailed)
8909: NOT 10:00:02.230185 VPNC: vpnc_send_notify: notify type: 1 [LoginFailed]
8910: NOT 10:00:02.230709 VPNC: vpnc_send_notify: notify code: 32 [DnsLookupErr]
8911: NOT 10:00:02.231221 VPNC: vpnc_send_notify: notify desc: [url hostname lookup err]
8912: NOT 10:00:02.231726 VPNC: vpnc_send_notify: sending signal 28 w/ value 13 to pid 20
8913: ERR 10:00:02.232321 VPNC: protocol_handler: login failed
8914: ERR 10:00:02.233275 VPNC: vpnc_recv_cmd_resp: cmd 0x00000300 [LOGIN], status: 0 [MCAPI_ERROR]
8915: NOT 10:00:02.234389 JVM:  --> Properties JNI: SignalApp() handling SIGIPCFG. msgCode=256 value=13
8916: ERR 10:00:02.250229 JVM:  --> IPCFG_VPN_NOTIF, SignalApp() handling SIGIPCFG. signal=0
8917: NOT 10:00:02.251709 JVM:  <-- Properties JNI: SignalApp()
8918: DBG 10:00:02.386775 VPNU: SM wakeup - chld=0 tmr=0 io=1 res=0
8919: DBG 10:00:02.390782 VPNU: State AppsUp --> AppsUp
8920: DBG 10:00:02.391406 VPNU: SM wakeup - chld=0 tmr=0 io=1 res=0
8921: DBG 10:00:02.391952 VPNU: State AppsUp --> AppsUp
8922: WRN 10:00:06.675159 JVM: Startup Module Loader|cip.sccp.SccpEnhancedAlarmInfo:setLastDeregistrationReason - new reason=LastTimeVPNConnectivityLost current=108,
8923: NOT 10:00:06.680650 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - propertyChanged - device.settings.security.vpn.mode value=false
8924: DBG 10:00:06.688020 VPNU: SM wakeup - chld=0 tmr=0 io=1 res=0
8925: DBG 10:00:06.689840 VPNU: saveBackupFile =>
8926: DBG 10:00:06.693081 VPNU: saveBackupFile <=
8927: DBG 10:00:06.693671 VPNU: saveDbFile saves a database
8928: DBG 10:00:06.705587 VPNU: mode changed
8929: DBG 10:00:06.762319 VPNU: sendConfigNotification: VPN state=3
8930: DBG 10:00:06.786876 VPNU: State AppsUp --> AppsUp
8931: DBG 10:00:06.787474 VPNU: SM wakeup - chld=0 tmr=0 io=0 res=1
8932: DBG 10:00:06.787991 VPNU: State AppsUp --> AppTerminate
8933: DBG 10:00:06.788484 VPNU: SM wakeup - chld=0 tmr=0 io=0 res=0
8934: NOT 10:00:06.789131 VPNU: Sending termination signals to apps
8935: DBG 10:00:06.794240 VPNU: Killing child /bin/vpnc, pid 11
Any ideas???
THANKS!!
Did you ever get this resolved? I'm having the same problem with a setup of two 5510s in HA. Laptops connect flawlessly but IP phones don't even attempt to make a connection. WE had this working with local usernames in the ASA. At one point we even had the LDAP (Active Directory) user/pass method working. Getting certificate-only VPN working has been a allusive though.
--Athonia
Re: 7942G Phone VPN Authentication Issues
Looking at the log you have a hostname lookup failure, this would point to a dns problem resolving your domain on the certificate
1208
