08-17-2010 10:58 PM - edited 03-16-2019 12:18 AM
Hi, The light strip on the handset do not light up even when messages are left in the mailboxes. Version used is CME 7.1 with CUE 7.1. I read that you need to set MWI on to the DN. With CUE 7.0 i have no problem with the below config. The light strip just worked. Can someone pls advise.
ephone-dn 90 dual-line
number 3890
label Testing - 3890
description (03) 8968-3890
name Testing
call-forward max-length 12
call-forward busy 3899
call-forward noan 3899 timeout 17
hold-alert 30 originator
08-17-2010 11:26 PM
Sounds like a dodgy firmware.
Upgrade/downgrade the 7945 firmware and try again.
08-17-2010 11:31 PM
Hi, I am using the below firmware, anybody encounter the same problem??
tftp-server flash:apps45.8-5-4TH1-6.sbn
tftp-server flash:cnu45.8-5-4TH1-6.sbn
tftp-server flash:cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:SCCP45.8-5-4S.loads
tftp-server flash:dsp45.8-5-4TH1-6.sbn
08-18-2010 12:41 AM
Downgraded 7945 firmware to SCCP45.8-5-2S. No joy....Problem still there. Anybody any suggestions.
08-18-2010 02:40 AM
Likely misconfiguration in CUE/CME MWI settings.
I recommend to use unsolicited notify that is the simpler option and works very well.
Note, there is a MWI refresh command from CUE for testing.
