7945 not working after a factory reset
Dears
I have a cucm 7.1.5.20000-6 and two 7945 phones
I did a factory reset to the first one "# 123456789*0#"
 now it hangs in the welcome message for 3 mins the it gives me  "auth fail"
The second phone I did the reset by "*# 3491672850*#" for it gives me a blank screen and nothing else, I checked the DHCP settings the network configuration they are OK
Any help would be REALLY APPRECIATED
Cheers
1 ACCEPTED SOLUTION
Hi.Ok so upload to CUCM the
Hi.
Ok so upload to CUCM the newest version  and upgrade again to 9.3.1-SR4 and see if it makes the difference.
If not, try the same procedure with a 8.5(2) version to than upgrade to 9.3 .
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.Try to reset tftp server.
Hi.
Try to reset tftp server. Probably you have an older firmware version on the phone than on CUCM.
Try to download the 8.5(2) version from the below link and upload to CUCM.
http://software.cisco.com/download/release.html?mdfid=281346594&flowid=46217&softwareid=282074289&release=8.5%282%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Reset the ftfp server and check on "Device defaults" if the load for 7945 has changed , otherwise change it to SCCP45.8-5-2.
After that, you can upgrade the phone to a newer version.
Carlo
Hi Carlothe 7945 firmware is
Hi Carlo
the 7945 firmware is SCCP45.9-3-1SR3-1S it's a new one !
Hi.
Carlo
Thanks MAN :) It's working
Thanks MAN :)
It's working
Glad that helped ;)  Regards
Glad that helped ;)
Carlo
27
