7945 only works on certain switches
Have an awkward one, a 7945 phone used to work wherever we put it now it will only work on certain switches (unfortunately not where our user community is based)
Have tried a software reset and removed from call manager and re-added. Is out of warranty, any ideas?
Hall of Fame Super Red
Re: 7945 only works on certain switches
Hi Weeyin,
This sounds like a PoE problem. The 7945's are a Class 3 PoE
device and will not work on "older" switches that provide Cisco
pre-standard power;
Power
Q. Do the Cisco Unified IP Phone 7965G and 7945G models support Cisco inline power?
A. No. The phones support only IEEE 802.3af PoE (Class 3).
Q. As Class 3 IEEE devices, do these phones require a continuous draw of 15.4 watts (W) (standard Class 3 allocation)?
A. No. When Cisco Unified IP phones are connected to common switches such as the Cisco Catalyst® 3560 Series Switches or Cisco Catalyst 3570 Switches, the switch can automatically detect the phone type and provide the exact amount of power that the phone needs. The use of Cisco Discovery Protocol provides this greater granularity to the power classification, allowing for more accurate reporting of power consumption, and a higher density of phones on the switch. The Cisco Unified IP Phone 7965G and 7945G models will draw a maximum of 12W from a switch; this places them beyond the limits of Class 2, but below the default 15.4W value of Class 3.
Q. Is there a recommended powering option for these phones?
A. No. Powering decisions depend on the customer's environment. The IEEE 802.3af inline power method can be used; alternatively, either the standard Cisco Unified IP Phone external power adapter or the Cisco Unified IP Phone Power Injector can be used for local power.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8537/prod_qas0900aecd80699c2b.html
Hope this helps!
Rob
Hi Rob,
Thanks for the reply, not sure it relates to the issue I am having at the moment though. All our switches are the same model and the phone works fine on some of them just not all of the switches we have.
On the switches that it doesn't work on there are plenty of other 7945s working fine from those switches.
We recently moved this one phone during an office move and it's since then that it is picking about what switches that it will work on.
Hall of Fame Super Gold
In addition to Rob's excellent post (+5 there mate), what specific model is your switch?  The reason why I'm asking is because a number of people would buy, for example, a 48-port PoE switch and they never realize that you can only power 24-ports (15.4w) on a first-come-first-serve basis.  So if you plug 25 7945 you only get 24 working and the 25th is dark.
And in light of this, some people get confused and say something like "but if I plug the contraption to another switch it works fine".
2321
