7945 Phone - Display Issue
Hey Guys,
I have a strange one for you. Running CUCM 8.6 with a bunch of 7945 Phones all running perfect. Bought 3 new 7945 PHones, configured and registed fine, BUT.. the display on all phones are cut, the display shows a 5mm strip on the left, then black for the remaining of the display. So, I RMA'd the phones and received e new replacement 7945's... BUT same problem.
However, If I plug an existing 7945 into the same CAT5 Port as one of the fualty phones, its display is fine.
I can only think firmware, but how are these new phone any different to the existing phones.
Have any of you seen or heard about this problem before.
Any suggestions.
I have attached a picture.
Ben
  • IP Telephony
1 ACCEPTED SOLUTION
Hi Benn,check the below bug
Hi Benn,
check the below bug id:
https://tools.cisco.com/bugsearch/bug/CSCui54479
You might need to upgrade the firmware to the latest available on CCO.
cmterm-7945_7965-sccp.9-4-2-1.cop.sgn
For test purpose, try to upgrade a single phone:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-ip-phone-7900-series/108090-upgrade-ip-firmware.html
Nitin Kapoor
Hi Benn,
Nitin Kapoor
Thanks Nitin, bumping up the
Thanks Nitin, bumping up the firmware worked.
55
