Community Member
7960 Auto Ring Extension When Handset Picked Up?
I need to place a phone at a locked door and have it ring an internal extension when the handset is picked up. Is this possible? I recall a posting some time ago about the same thing, but cannot find it. Any help will be apreciated.
Currently running old version of call manager 3.2.(2c)spH
Randy
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 7960 Auto Ring Extension When Handset Picked Up?
Hi Randy,
This type of Hotdial "Bat-Phone" setup is very possible. Have a look;
Hotdial on IP Phones with CallManager Configuration Example
How to configure a Cisco IP Phone for Private Line Automatic Ring-down (PLAR) or Hotdial with Cisco CallManager. With PLAR configuration as soon as the phone goes off-hook it dials a pre-configured number. This be done by making use of calling search spaces (CSS), partitions, and translation patterns.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml#intro
Hope this helps!
Rob
Community Member
Hrmm. On 4.1.3sr2 you can setup a blank translation pattern in a "LockedFrontDoorPT"; set the CSS to an internalonly and change the Called Party Transform Mask to whatever internal number you want to be called. Create a CSS that has the LockedFrontDoorPT in it. On the device, point the CSS at the one that you just made.
Hi Randy,
From this good doc;
Hope this helps!
Rob
Community Member
Thanks Rob, exactly what I was looking for. Set it up in less than a couple mins and worked perfectly!
633
