7960 Caller Information display from 2nd or 3rd Line
Wondering if it's possible to show the Caller information on 7960's 2nd or 3rd line
Here is a scenario
Phone A, Phone B and Pone C all have an emergency line setup as their 3rd line.
A SIP Emergency button is part of Hunt group and when pressed, sends a call to all three lines on Phone A, B and C.
The issue I'm seeing right now is if anybody is on a call on their primary lines, we can't see the Emergency buttons informationi on the phone's display if the button is pressed.
Becaus I have a 7975, I can see that the display of the 3rd line is under the primary display when I'm on my primary line.
Is there a way to force the 3rd line display to be priority when it rings? Or at least move it down the screen so that we can see it?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Julien,
On the 7960 Device page in CUCM under the product Specific config
change Auto Line Select to  > Enabled
Cheers!
Rob
Re: 7960 Caller Information display from 2nd or 3rd Line
Make sure in the line setting the busy trigger is set to 2 or higher
Busy trigger for line 3 (Emergency line on all phones) is set to 2.
So basically “Maximum number of calls = 4”
“Busy trigger = 2”
Julien Franche
Systems Administrator / Ottawa
Tél./Tel. 613-233-1781 x50124
gowlings.com <>
Hi Julien,
Cheers!
Rob
Nice one rob :)
335
