03-04-2007 03:08 PM - edited 03-14-2019 08:18 PM
I have the 7960 set up on a VPN which other applications use. There seems to be no conflict with other system applications.
After the initial configuration, calls can be received and made successfully for about 3-5 minutes and then nothing connects.
Outbound calls have fast "busy" signal after about 30 seconds of nothing.
In-bound calls will not successfully pick up the incoming line.
Calls to other extensions and the voice mail system end with a fast "busy" signal.
I am using a DSL filter on the incoming IP line and have tried removing with no luck.
Thank you for your help.
03-04-2007 05:18 PM
is this CCM or CCME ?
can your browser open telephone's web page from the remote end of VPN ?
03-05-2007 07:16 AM
Yes, we can open the browser from the remote end of the VPN
03-05-2007 11:01 AM
I am on the server end. Tim is my user. We are using CCM 3.3. I have never seen this type of problem before. This was a phone purchased from eBay by the user. Other than that, it's the same as we always use. We wiped the config and set it up the way all of our other phones are setup but no go.
Any help is very much appreciated.
03-12-2007 05:11 AM
SOLVED:
Problem was with deep packet inspection on the remote VPN router. Increased DPI settings to max and it now works.
