05-13-2008 12:21 PM - edited 03-15-2019 10:38 AM
I cant figure out for the life how to get the old SIP firmware off the 7960/7940 phones and switch to Skinny. I tried 79XX.TXT file and it gets me no where. Anyone have a shortcut way to make this work?
Thanks!
05-13-2008 12:31 PM
Are you doing the factory reset ?
Can you capture the tftp transactions ?
05-13-2008 12:38 PM
I tried the factory reset with holding down the button and waiting for the blinking headset, hold, etc and couldnt get it to work
05-13-2008 12:43 PM
You need to caputure the tftp messages, use a router or tftpd32.exe for that. Usually the reason is that phone is looking for some file and not give. Also, you can try loading first, an old sccp image, like 5.x
05-14-2008 07:07 AM
yeah, on the phone status we could see which file it wanted and in the log. Even though we put the file in the TFTP dir, it still would not take it.
05-14-2008 07:21 AM
Are you using tftp32d or what? If the phone request the file and is there, it must be given.
05-14-2008 07:23 AM
Tried TFTP32 and the CUCM server. couldnt get it to work. It's the original SIP 3x load
05-14-2008 07:28 AM
Please paste log of tftpd32 and content of OS79XX.TXT file.
