7960G IP Phone access control
I have Call Manager 7.1.5  and  7960 phones  which will be set up as a community assets in common areas.  I  need to  restrict use of the phones  to a specifc group of authorized users. Active Directory and 802.1x are not available only local Call Manager  authentication. Need help with any suggestions as to how to secure the phone for authozied users only. Thanks
Everyone's tags (4)
1 ACCEPTED SOLUTION
Blue
Re: 7960G IP Phone access control
I believe you can do two things, following are two CUCM feature.
1) Either use Extension mobility and give username and password to specific authorized users.
2) You can use FAC and Client Matter Code feature.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Ronak Patel
Thanks for the support
213
