Community Member
7960G IP Phone
I have Call Manager 7.1.5  and   7960 phones  which will be set up as a community assets in common areas.  I  need to  restrict use of the phones  to a specifc group of authorized users. Active Directory and 802.1x are not available only local Call Manager  authentication. Need help with any suggestions as to how to secure the phone for authozied users only. Thanks
Everyone's tags (4)
1 ACCEPTED SOLUTION
7960G IP Phone
With that requirements the only in-built solution would be EM, if this was only external calls FAC/CMC would do.
If you don't want to use EM, then you would need a 3rd party solution.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Silver
7960G IP Phone
Can you elaborate on what you  want to secured?
Is it for making calls by authorized persons?
Or access to Settings, etc?
Chris
Community Member
7960G IP Phone
Hi Chris,  making calls by authorized persons is what I'm going for. Thanks
7960G IP Phone
And are you talking about internal calls or external calls??
java
java
Community Member
7960G IP Phone
This would be for both internal and external calls
7960G IP Phone
java
java
Community Member
7960G IP Phone
Forced authorization codes and extention mobility I'll start working on both of these. Thanks!
7960G IP Phone
For internal blocking you can use Calling Search Spaces/Partitions to build the separation. For external depending if you want this statically you would also use CSS/PT and Route Patterns, or if you want to be able to overwrite the setting use Forced Authorization Codes.
HTH,
Chris
275
