7960G phone
jenny_flannigan
We have user who has 7960G phone with two line buttons and the other four buttons setup as speed dials. He wants to be able to see if the speed dial persons are on the phone. Can this be done
William Bell
Jenny,
The feature you are looking for is called Busy Lamp Field (BLF) and it is not supported on the 7960 IP phone.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmfeat/fsprsnc.html#wp1134925
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks Bill
On the screen of the 7960 phone the line numbers have little telephones and the speed dials have box of little lines. Is there anyway the speed dial "box of little lines" can change if the user is on the line?
Jenny,
Sorry.  Again the feature you describe is called BLF and it is not supported on the 7960.
HTH.
Bill
