06-09-2010 12:32 AM - edited 03-15-2019 11:09 PM
I have a 7961 phone with 7914 Expansion module. On the expansion module, all the lines are red.
Here is my version output:
yourname#sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 13:10 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
yourname uptime is 3 hours, 1 minute
System restarted at 13:47:45 UTC Fri Apr 22 2010
System image file is "flash:c2800nm-spservicesk9-mz.124-15.T9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 243712K/18432K bytes of memory.
Processor board ID FCZ13224346
2 FastEthernet interfaces
1 terminal line
2 Channelized (E1 or T1)/PRI ports
2 Voice FXO interfaces
1 cisco Integrated Service Engine(s)
Cisco Unity Express 3.1.1 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
yourname#show telephony-service
CONFIG (Version=4.1(0))
Version 4.1(0)
Cisco Unified Communications Manager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 192.168.10.254 port 2000
load 7910 P00403020214
load 7960-7940 P00307020200
max-ephones 32
max-dn 32
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message Public
edit DN through Web: enabled.
edit TIME through web: disabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp Jan 01 2002 00:00:00
transfer-system full-consult
auto assign 1 to 32
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
yourname#sh fla
-#- --length-- -----date/time------ path
1 44446708 Jun 24 2009 15:23:02 +00:00 c2800nm-spservicesk9-mz.124-15.T9.bin
2 2748 Jun 24 2009 15:32:44 +00:00 sdmconfig-2811.cfg
3 931840 Jun 24 2009 15:33:02 +00:00 es.tar
4 1505280 Jun 24 2009 15:33:24 +00:00 common.tar
5 1038 Jun 24 2009 15:33:38 +00:00 home.shtml
6 112640 Jun 24 2009 15:33:54 +00:00 home.tar
7 1697952 Jun 24 2009 15:34:20 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
8 415956 Jun 24 2009 15:34:40 +00:00 sslclient-win-1.1.4.176.pkg
9 281506 Jun 24 2009 15:39:48 +00:00 ATA030100SCCP040211A.zup
10 638 Jun 24 2009 15:39:48 +00:00 CME_GUI_README.TXT
11 331101 Jun 24 2009 15:39:48 +00:00 CP7902060000SCCP050124A.sbin
12 338897 Jun 24 2009 15:39:50 +00:00 CP7905060000SCCP050124A.sbin
13 338481 Jun 24 2009 15:39:52 +00:00 CP7905060000SCCP050124A.zup
14 340247 Jun 24 2009 15:39:54 +00:00 CP7912060000SCCP050124A.sbin
15 1602 Jun 24 2009 15:39:54 +00:00 CiscoLogo.gif
16 953 Jun 24 2009 15:39:54 +00:00 Delete.gif
17 128792 Jun 24 2009 15:39:54 +00:00 P00307020200.bin
18 458 Jun 24 2009 15:39:54 +00:00 P00307020200.loads
19 680394 Jun 24 2009 15:39:56 +00:00 P00307020200.sb2
20 129196 Jun 24 2009 15:39:58 +00:00 P00307020200.sbn
21 333822 Jun 24 2009 15:39:58 +00:00 P00403020214.bin
22 1347 Jun 24 2009 15:39:58 +00:00 Plus.gif
23 47904 Jun 24 2009 15:40:00 +00:00 S00103020002.bin
24 49169 Jun 24 2009 15:40:00 +00:00 S00104000100.sbn
25 174 Jun 24 2009 15:40:00 +00:00 Tab.gif
26 4448 Jun 24 2009 15:40:00 +00:00 admin_user.html
27 656913 Jun 24 2009 15:40:02 +00:00 admin_user.js
28 1045952 Jun 24 2009 15:40:06 +00:00 cmterm_7920.4.0-02-00.bin
29 16948 Jun 24 2009 15:40:06 +00:00 dom.js
30 864 Jun 24 2009 15:40:08 +00:00 downarrow.gif
31 6315 Jun 24 2009 15:40:08 +00:00 ephone_admin.html
32 4658 Jun 24 2009 15:40:08 +00:00 logohome.gif
33 496521 Jun 24 2009 15:40:10 +00:00 music-on-hold.au
34 3831 Jun 24 2009 15:40:10 +00:00 normal_user.html
35 78819 Jun 24 2009 15:40:10 +00:00 normal_user.js
36 843 Jun 24 2009 15:40:10 +00:00 sxiconad.gif
37 2453 Jun 24 2009 15:40:10 +00:00 telephony_service.html
38 870 Jun 24 2009 15:40:10 +00:00 uparrow.gif
39 10230 Jun 24 2009 15:40:10 +00:00 xml-test.html
40 3389 Jun 24 2009 15:40:10 +00:00 xml.template
74186752 bytes available (54550528 bytes used)
My Config for 7961 :
ephone 3
no multicast-moh
mac-address 0024.C4BE.2D12
keepalive 30 auxiliary 0
type 7961 addon 1 7914
button 1:1 2:32
Is there a problem with my phone load or ios? I am powering Expansion Module with power cube.
Solved! Go to Solution.
06-12-2010 05:28 AM
First, you don't seem to have a load file set up for the 7914 - it has it's own firmware that you need to specify in a 'load' command under telephony-service (the filename is prefixed S001, e.g. S00103020002)... also make sure it's available over tftp as with the other load files.
Secondly, you have buttons 1 and 2 assigned to DNs 1 and 32 respectively.. once you have the firmware downloaded OK you will need to assign DNs to the buttons on the module.
Aaron
Please rate helpful posts...
06-12-2010 05:28 AM
Aaron
