7961 Tone Generator
Can anyone tell me how to user the Tone generator on a 7961, if it has one !
I have followed the instruction on CCO for the 7960 but I do not get a "tone" softkey.
I can find no instruction for a 7961 but this is the only phones we use, any help ?
1 REPLY
Hall of Fame Super Red
Re: 7961 Tone Generator
Hi Andrew,
I think you might be hitting this bug;
CSCee44462 Bug Details
Headline Need ability to generate inband test tone on 7941/61/70/71 like 7960
First Found-in Version 8.0(3), 5.0(1)
Status Assigned
Symptoms:
7941/61/70/71 phones cannot generate 1004Hz -15dB test tones the way a 7960 is capable of doing.
Conditions:
Any network where 7941/61/70/71 phones are being used and a test tone is needed to troubleshoot a loss plan or echo problem.
Workaround: Use the test tone on a 7940 or 7960.
Hope this helps! Sorry man.
Rob
651
