Community Member
7961G-GE Install problems
I was trying to connect a 7961g-ge to our network. If I understand correctly now after looking the 7961g-ge does not work with CM 4.0. To my question: I tried to use it with apower brick and it started and then shutdown. I think I figured out what I did and now I am wondering if there is a solution. I plugged it into the power brick and then I plugged a cable with POE into the phone. The phone won't power up now. Is this fixable or did I mess it up?
Green
Re: 7961G-GE Install problems
If no power up now, you can try to test the phone with a PoE switch or with a different power brick if u dont have a different power brick try different phone...
Not too much to do since will be phisycal other than replace either Phone or PW brick
Community Member
Is there any kind of reset or fuse inside the phone that might have been tripped that I can fix? The Power Bricks are fine.
Community Member
Any Ideas? I am in a bind here. Thanks.
Community Member
Does it power on with the power brick now or doesn't power on at all?
Community Member
It "does not" power on with the power brick now.
Community Member
It Does not power on with the power brick. Is there a reset or something inside the phone?
120
