7961G keeps registering repeatedly
Two 7961G phones on the same switch keep registering repeatedly on their own. I didn't find any strange settings with the switch but then again I am fairly new to Cisco.
Any help is appreciated!
Andy
Hall of Fame Super Gold
Re: 7961G keeps registering repeatedly
Are you using CME or CM ?
CME 4.0
Andy
Can you check the phones are getting an address from the router and there isn't a rogue dhcp server around.
No rogue dhcp going on anywhere on the network. Any other thoughts?
Andy
Send show interface for the ports involved.
I hope this is what you mean...
Gatehouse-Top#show interfaces fa0/6
FastEthernet0/6 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0024.5186.2a88 (bia 0024.5186.2a88)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 2000 bits/sec, 3 packets/sec
213963 packets input, 25166233 bytes, 0 no buffer
Received 8026 broadcasts (0 multicasts)
0 watchdog, 2656 multicast, 0 pause input
787873 packets output, 106528429 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Gatehouse-Top#show interfaces fa0/14
FastEthernet0/14 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0024.5186.2a90 (bia 0024.5186.2a90)
Last input never, output 00:00:00, output hang never
5 minute output rate 4000 bits/sec, 3 packets/sec
281337 packets input, 68577875 bytes, 0 no buffer
Received 1332 broadcasts (0 multicasts)
0 watchdog, 8 multicast, 0 pause input
859669 packets output, 388339871 bytes, 0 underruns
Also, they are both 7931 models, not 7961. Sorry.
Allright go ahead and upgrade firmware. I haven't checked what the latest is.
If you havent tried, please perform a factory reset.
that has helped in one of our phones doing similar things.
263
